Internet for an iPad without a computer?
Hinezy
May 24, 2008
533
56
Mt.Carmel, PA
I have a friend that is getting an iPad and cable Internet to run it. He doesn't have a computer, will a wireless router run without a computer? If so how do you give it a password? Any help would be appreciated.
Sent from my 32Gb iPhone 4S using iCafe app
RoofMonkey
Jun 21, 2010
8,924
1,984
It will work ok. You can log into the router through the iPad and adjust settings. Most routers default to using 192.168.1.1 or similar to get into the settings. Documentation with the router will give the default username / password also.
