Internet on unlocked iPhones
barry
Oct 9, 2007
I was wondering does the internet work on other carriers. For example if i were to put a vodafone sim into the iPhone would i be able to use the web browser using the vodafone internet.
amedina
Sep 22, 2007
25
www.flickr.com
You certainly can! If the mobile operator has an EDGE capable network, you'll be ok. I bet Vodafone's got such services no problem whatsoever.
I'm using EDGE on a Chilean local mobile carrier, EntelPCS.
So if I can use it, you probably can. Only thing is to know your EDGE settings right.
barry
Oct 9, 2007
Thanks a lot for that i just bought an unlocked iPhone from ebay, so exciteddd.
marcdw
Oct 11, 2007
yes the phone does work on vodafone in australia but vf does not have edge and it is very slow
marcdw
Oct 11, 2007
edge settings
could someone tell me how to put into the phone the edge setting where do i do it
CurtisS
Oct 16, 2007
Edge settings for UK
Dear Alan,
I'm in the UK too with my iPhone 1.0.2 on Vodafone. What are the correct settings I should use to enable Edge?
C
barry
Oct 9, 2007
Dear Alan,
C
Hey i jus found thios out yesterday, Basically what u do is go to settings,
then go to genral, then you go to network. then go to EDGE. then .... Your
APN: internet
Username: web
Password: web
Use those settings it worked for me
BTW im on contract diffrent settings for PAYG
CurtisS
Oct 16, 2007
Thanks - it works! it's a bit slow though... but I suppose that's EDGE for you...
Best wishes
C
CurtisS
Oct 16, 2007
Voice message?
Dear Barry,
could you also tell me what to do to get my Voicemail working like it should... I don't seem to be able to open the special iPhone Voicemail page - it just stays on whichever Phone Tab it was on previously (ie Contacts or Keypad...)
C
Dec 28, 2007
If i buy a iPhone unlocked will i have to pay any extra charges for i.e Safari (internet) or is it free. Also i would like to know are unlocked iPhones the same as contract iPhones from the O2 shop. Many Thanks Flanneryryan93
Apr 22, 2008
Tmobil Edge settings for iPhone
I just unlocked my iPhone to use with tmobile and everyt thing works great but I don't have internet. does any one know what the edge settings are for tmobile. Thank you
p7jnp
Apr 17, 2008
9
I have a unlocked iPhone. I set up with Orange to have off peak internet browsing but after just speaking with orange they tell me I need to know my WAP settings? Any ideas anyone?
nairny
May 7, 2008
9
Dorset UK
great
cheers barry, I put those settings in for Vodafone in the UK and they work like a dream, even though Vodafone told me they did not support iPhone, nice one
colski78
Apr 25, 2009
hi
im having terrible troublw with my unlocked iPhone.im on vodafone uk and cannot connect to the internet the only way i can is through wi-fi.ive put the correct settings in internet web web there is no edge present in settings and people on the forums say you need edge present but its not there.
help!
colski78
Apr 25, 2009
hi im having terrible trouble with my unlockediPhone on vodafone network.the only way i can connect to the internet is through wi fi but one im out the house i obviously cant use it anymore.ive got internet web web in the settings but there is no edge present in the settings for some reason please help
jennyleac
Jul 10, 2010
Is it possible to get the 10 dollar internet plan for tmobile with the unlocked iPhone? Will it recognize it and be able to work?
