Invalid Password?
yakob89
Apr 16, 2008
134
Albuquerque,NM
Hi so I just recently got a new iPhone 3G from the Apple store because the casing on my other one was cracking. However now I have a new problem. My phone keeps bringing up this ivalid password for voicemail and keeps asking me to enter my password. The problem is I never even set password for my voicemail what should I do should I try and erase everything and then get all my information from backup? Idk any help would be very much appreciated.
Dec 15, 2008
5,386
340
Pensacola, FL
Try to restore from backup. If you still get same error(s), call AT&T. They have an option for Voicemail Assistance.
iNinja
Aug 8, 2008
3,984
20
UK
It could be something to do with your back up so I would restore as a new device. That should clear it.
LDT
Aug 19, 2008
34
Had the same problem with my new 3GS. I called AT&T and they reset it for me but said that the password is your phone number including area code.
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
Just dial "1" from your phone. If you've never set up a password, it will take you right in. From there, navigate through the voice menu's until you get to change/set your password. Once you change it, your iPhone will prompt you saying Invalid Password... just put in the new password you created.
yakob89
Apr 16, 2008
134
Albuquerque,NM
Ok so I tried dialing one and for some reason it said "Error performing request No Network Service" I think I'll call AT&T and see if that works thanks for helping out guys I really appreciate it!
KabaModern
Mar 31, 2008
4,549
32
That's really strange. Yep, AT&T is your best bet now. GL!
yakob89
Apr 16, 2008
134
Albuquerque,NM
alright guys I fixed it! I was just retarded I had to go and hold 1 till it went to my voicemail and fixed it and changed the password thanks for the help guys!
