Invisible slider
perks
Oct 28, 2008
44
Does anyone know how to if its possile to have no slider at bottom of screen or make it invisible?
5,578
Yes, many lockscreens have this feature included. Some have an invisible slide to unlock and some have invisible tap to unlock.
You could install "Invisible tap to unlock" in Cydia. I have all the repositories on my phone, so if it doesn't show up for you, first install Stefwiz's repository and then All repositories and search again.
perks
Oct 28, 2008
44
ok Thanks for advice ill try it.
PepeRB29
Mar 21, 2008
1,500
8 mile
if you want the invisible slider just install "Ununlockable" in cydia. love that feature, all the retards can't figure it out when trying to look at my iPhone, its quite comical :)
5,578
Yep, that's it, I knew it had to be there somewhere.
"Un-Unlockable" makes the slide to unlock graphics/text invisible, but it still functions like it normally would, just slide your finger across the bottom of the screen to unlock.
perks
Oct 28, 2008
44
cheers guys great little app makes lock screen look so slick! It also removes the transparent bar behind the time too,
