Invisible statUSBar with istatUSBar.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
I'm not sure how well it works, I don't need it since I'm jailbroken but I hate it that statusbar black. Maybe if someone buys it can use this thread to upload some wallpaper for other to use too.
TH55
Oct 30, 2011
356
9
So I unfortunately just tried this and have to report that it does not work. While it does lighten the status bar, it is still clearly visible. Thanks anyway, is there any way to fully remove it when jailbroken?
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
Transparent StatusBar for iOS4 (Winterboard Theme) works.
Edit: I beg your pardon, this (the jb app) makes the status bar itself "invisible" but all the graphic elements like battery, clock, signal bars, etc. are still there.
TH55
Oct 30, 2011
356
9
K sorry, thought since they were two diff forums I might get a wider variety
Sharunda
Jun 16, 2008
4,992
1,082
One Horse Town, New Jersey
Edit: I beg your pardon, this makes the status bar itself "invisible" but all the graphic elements like battery, clock, signal bars, etc. are still there.
So Kadelic, are you saying that the App (non jailbreak App) does actually work and makes the Status bar itself invisible or are you saying that the jailbreak Transparent StatusBar makes the Status Bar invisible?
I'm sorry, I just need clarity, the statement confused me, not sure which you were posting the bottom edit for.
Sorry in advance if I am confusing you with the question. :oops:
The App Store app works with really dark wallpapers, but it not light ones. It failed to make them transparent, IME.
The Cydia app works as advertised and makes them transparent. See link in post #13. We posted screenshots.
  • Like
Reactions: Kadelic
Sharunda
Jun 16, 2008
4,992
1,082
Thanks for splainin' that to me. I think I'll try the App. I'm not going got jailbreak.
