InvisibleShield or BodyGuardz
ZJH90
Jul 26, 2007
105
San Francisco!!!!
Which of these is better? I finally decided to use a skin rather than a bulky case, but now I can't decide which skin is best. Right now, I am leaning more towards the InvisibleShield. Please let me know what you all think. All help is greatly appreciated.
Headie_Fishing
41
Try doing a search for both of the products. From everything that I read it sounds like Bodyguard is the best option as far as coverage and grip as well as being the least obvious. I just ordered the bodyguards a few hours ago and was a little disappointed in the price, coming to 32.95. Another, cheap option is the bestskinsever which is only $7.95.
Do a search, the topic has been covered extensively with many indepth reviews and comparisons.
ZJH90
Jul 26, 2007
105
San Francisco!!!!
My only problem is that all the reviews for these things all say the same thing about the product... Has no one here ever used one of these products?
jeepshots
Jul 10, 2007
68
I've got the Invisible Shield on mine. The full body version - a piece for the front and a separate piece for the back. While I like the back wrap-around protection, and it's tacky feeling, I don't like that same feeling for the screen side. So I'm gonna be replacing the screen side with a Crystal protector - supposedly its made of that superslick plastic.
kcarr91
Apr 14, 2007
62
i have the Invisible Shield front cover i love it it a little tacky but i kinda like it (but i can see if the whole iPhone was covered in it it might feel alittle weird) i plan to use it with the iskin revo case so i only got the front sheild i am very happy with it and no bubbles 5 min after applying it
it depends on what you like (i guess)
i am very happy with the Invisible Shield
(plus the fact that they will replace it if it get ripped or torn for free is really nice)
sickmunkeyz
Jul 4, 2007
75
the bestskins one is the best. its made of same thing as invis shield only a lot cheaper. i have it on mine right now. works great. used it on my blackberry pearl and curve also.
I purchased the Invisible Shield for the iPhone and when I got it. Installation was not the easiest even though I have used SEVERAL of their products before. I had to eventually take it off because it was turning a pale yellow color. Also when I removed it, It pulled off the serial number and iPhone type and everything on the back. Good thing Apple put enough there so I can still read it. Last time I use Invisible Shield...
