iOS 5.0.1 battery usage incorrect?
KabaModern
Mar 31, 2008
4,549
31
Philadelphia, Pennsylvania
Does anyone else have the issue where the Usage time is incorrect on the 4S? For example, I took it off the charger this morning, and have only actually used the phone for around 15 minutes, however the stats are showing up:
Usage 1 Hour, 14 Minutes
Standby 1 Hour, 56 Minutes
That is completely wrong. My usage should only be about 15 minutes or so. I've tried a DFU restore, set-up as new phone, and drained the battery down until it powered off.
Suggestions?
iphonewarrior
13,847
699
I use the 4 and can honestly say I've not seen bogus Usage results. I would look at getting your phone replaced :)
6,683
51
I have seen where the usage and standby are the same, but it was because an app (or webpage) was hung running in the background. I closed everything, and then rebooted, and then a hard reset. If that doesn't work for you, then I have 2 other suggestions.
1) under Settings, General, Reset- reset all settings.
2) run the phone down till it's dead. Turn it on and if you are able, run it down further. Then Charge uninterrupted to 100% (and about 30 minutes after it hits that.) then test again. If you are still having the same problem, take it to Apple and explain everything you have done. They should replace it at that point.
** I will point out that I am NOT a fan of completely killing the battery, as it can do damage to it in the long run. But in this case, I can see it as a possible necessity, plus it will start you off completely fresh with the battery meter.
I never seen it before, either. I'm really not sure what is going on. Apple has already replaced my battery, I think I'll take it back to the Genius bar for a phone replacement.
Yeah, but the firmware is different for the 4S. I think it's software-related. I'd say wait for 5.1 rather than replacing the hardware. It will probably be less than a month and the phone is functional for the time being.
Apple iAddicted
Feb 20, 2012
269
27
Your settings could be checking mail and facebook and such mine was and ate up battery had to charge twice a day, I get a lot of mail on 3 servers. I have everything set to manual check and keep my cellular data turned off unless I'm using it and my usage time is dead on. Since I figured out how to control the data hoggs my battery lasts all day too.
KabaModern
Mar 31, 2008
4,549
31
Well, Hawk this was odd. I did all those suggestions over this past weekend to no avail (battery still sucked and the usage was reporting incorrectly). Today, my battery is so much improved it's almost unbelievable, and the usage is completely accurate. I have no clue what happened but so far it seems to have fixed itself.... :confused:
6,683
51
That is weird. I am glad it's fixed, but if it was fixed because of you doing my suggestions, then that is one heck of a delayed reaction.
KabaModern
Mar 31, 2008
4,549
31
I spoke too soon. It worked for a day, now it's back to it's normal (crappy) behavior. Also, my iPhone won't stay turned off. When I slide the red slider, I get the spinning wheel and then the Apple logo automatically comes right back on and it boots up. Taking to a Genius today for a replacement.
6,683
51
I solved this problem restoring the software.
That is the simplest way to fix it. unfortunately, it's a pain in the butt, and most importantly, it doesn't always fix the issue.
KabaModern
Mar 31, 2008
4,549
31
Right, that did not fix the issue for me. I did a complete DFU mode restore and set it up as a new iPhone and it still had the issue. It was obviously the phone itself because my new one is working just fine.
Apple iAddicted
Feb 20, 2012
269
27
Everything has lemons get in the bunch. Could of been a defective chip, something loose, or (sacastic) someone sneezed before they finished building it lol. Important thing is Apple stood by and replaced the faulty device.
Love Me Or Hate Me I'm A TechnoGeek, And I Will Express My Opinion! That's What Forums Are For! Sent from my iPhone using iCafe app!YaHoo!
