iOS 5 beta 3
slayer666
Aug 13, 2009
122
I just installed IOS 5 beta 3 and did the back up from iCloud all my apps but 3 loaded and when I go into the iCloud to do a another back up it comes up with this (pic below). Now would a simple restore will help fix this and see if all the apps load this time? Is anyone else having the same problems?
Cheers Joe
Sent from Joe's iPhone using iCafe app
gotzaiPhone
Jun 16, 2008
1,177
Tinley Park, IL
I had that same problem from beta one to beta two. I had to delete my iCloud backup in order for that message to go away. But per the recommendation of Apple, I reverted back to using iTunes for the backup. That was part of the release notes that iCloud isn't 100% yet.
However, I never shut off contact and calendar sync to iCloud and all my info was re-synced after the beta three update.
