iOS 5 Guide
InyigoMontoya
Jun 17, 2011
311
Indiana
NYTimes, Boston Herald, various blog sites. Searching Google, I'm finding that it was missing from the 3GS in early iOS5 Betas. Looks like it's missing from the GM too. Isn't there supposed to be an icon up by the URL field?
InyigoMontoya
Jun 17, 2011
311
Indiana
Cool little thing - when you're scrolling through your texts, if you swipe your thumb down over the keyboard, the keyboard scrolls off the screen so you can see more messages.
  • Like
Reactions: Ellie R.
talon90
Jan 17, 2009
290
29
It's there on my phone (iPhone 4, iOS 5). It appears that there are some specifics about using it. For example, I can't get it to come up on any page that is all ready clipped (mobile site or url that starts with an m.). These are all ready formatted and truncated so there is nothing for the reader to do.
It also doesn't come up on the home page. You need to find a site that is broken in to articles or sections. Click on one of the articles and you should see the reader button appear up in the bar.
For example, go to www.roughguides.com and then click on any one of the articles on the main page. This is the site that is actually shown on the Apple page that features the reader. If you click on any of the articles, you'll get the button.
InyigoMontoya
Jun 17, 2011
311
Indiana
Yeah I knew about mobile sites. It appears it's just simply not available for the 3GS.
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
can't seem to get any notifications to work in the new notify center. Except the stock weather app. I've turned them all on in settings, did the banner option and badge option but when I swipe down all I get is the weather. Nothing from my calendar, my reminders, etc.
Suggestions?
InyigoMontoya
Jun 17, 2011
311
Indiana
Try sending yourself a text message and hitting the sleep button right after you send. You should see it pop up on your lock screen. Unlock then swipe down for NC and see if it's there.
InyigoMontoya
Jun 17, 2011
311
Indiana
All your calendar events and reminders - those should show up in the NC too (when you swipe down from the home screen). Were they there?
InyigoMontoya
Jun 17, 2011
311
Indiana
Try setting a new reminder and then check NC for it. Should be there. Only new, unread emails are showing up so far for me.
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
Yeah I got a reminder to show. Don't know how far out they show up in the NC. Wonder if there's a way to change that? Must be the same way with the calendar events.
