iOS 5 software issues on iPhone 4
speedform
Jul 21, 2010
So I can't seem to find a definitive fix for some of the issues I'm having after downloading the new IOS 5 software to my iPhone 4.
1. cannot add new contacts to contact list: the '+' sign no longer shows up in the upper right corner.
2. cannot add an event to the calendar
3. wifi sync box won't allow me to click on it. weird
Any ideas? Powering down and restarting doesn't seem to work. Thanks ya'll
Jmbaker429
Jun 28, 2010
994
144
35
I think someone else was having the same problems recently. If youve already done the hard restart. Try restoring and setting up as new and not a backup.
Jmbaker429
Jun 28, 2010
994
144
35
Correction I see you did not try a hard restart only a power down and reboot. Try a hard restart. Hold down power and home buttons until you see the Apple logo and then release.
RoofMonkey
Jun 21, 2010
8,921
1,983
For the wifi sync issue, you have to plug into iTunes with cable you normally sync with. Then it should let you choose the box for wifi sync.
