iOS 5 text tone question.
Daking618
Oct 31, 2010
112
Miami Fl
Since you don't have to plug your iPhone into the computer now. The apps that lets you create your ringtones from The music you have on your iPod. How can we do this without hooking it to the computer?
Tonynlia
Oct 15, 2011
32
When your phone is visible in iTunes you can just set up your ring tones as before,the only difference is you are doing it wirelessly
Tonynlia
Oct 15, 2011
32
Once you have created the ringtone and have the ringtone box ticked in iTunes you should go to your phone and click the sync over itun
Tonynlia
Oct 15, 2011
32
Click the sync over wifi and the sync should begin ,a double arrow on your phone should start rotating showing the sync is working
Tonynlia
Oct 15, 2011
32
Hope it worked ,I have just set up a ringtone on rt wizard and added it to ringtones on iTunes, I then made sure the everything was ticked and then completed the sync without using any cables
