iOS 6.0.1 Released Thread
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
Here's the changelog:
This update contains improvements and bug fixes, including:
  • Fixes a bug that prevents iPhone 5 from installing software updates wirelessly over the air
  • Fixes a bug where horizontal lines may be displayed across the keyboard
  • Fixes an issue that could cause camera flash to not go off
  • Improves reliability of iPhone 5 and iPod touch (5th generation) when connected to encrypted WPA2 Wi-Fi networks
  • Resolves an issue that prevents iPhone from using the cellular network in some instances
  • Consolidated the Use Cellular Data switch for iTunes Match
  • Fixes a Passcode Lock bug which sometimes allowed access to Passbook pass details from lock screen
  • Fixes a bug affecting Exchange meetings
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
Have to DL a iOS enabler app first? Different, at least to me. Thanks for the heads up Chris!
Sent from my iPhone 5 using iCafe app
Rafagon
Dec 7, 2011
7,569
1,227
47
Miami, Florida
It looks receipts from iMessages are a tad more specific. Whereas before you would only see "Delivered," now you see "Read hh:mm." Also, based on my experience, this seems to work even when the recipient of your text message has updated to iOS 6.0.1 and you're still on 6.0.
You'll notice that the accuracy of the timestamps may not be 100% reliable. This person read my iMessage at 3:38PM, and I received their reply at 3:37PM. :confused:
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Read receipts have been on the iPhone for a long time. Not just with this update. It's an optional setting though in Settings.
Smarty2600
Apr 23, 2011
344
11
Hmm, I'll update later when the servers are less busy, but I was hoping that the bug fixes would address my iPod touch 4th gen's inability to stay to connected to wifi while it's in sleep mode. Bummer, nothing on this list effects me. Also I haven't been able to access my purchased apps because the app store crashes, any idea on how to the fix that?
15,385
1,023
...I was hoping that the bug fixes would address my iPod touch 4th gen's inability to stay to connected to wifi while it's in sleep mode.
This isn't a bug; it's by design to save battery life. If you want it to stay connected in sleep mode, you have to have it plugged into power.
Rafagon
Dec 7, 2011
7,569
1,227
47
Miami, Florida
So when I see "Delivered" after I send an iMessage, it means the person does not have Read Receipts on, but when I see "Read hh:mm," it means that person has "Send Read Receipts" set to on?
I was under the impression that the "Send Read Receipts" setting was only to send the word "Delivered" out; today was the first time I saw "Read hh:mm" from anyone, and it happened right after this person updated to 6.0.1, so I thought it was a goody provided by 6.0.1!
mrbunglez
Mar 20, 2008
439
100
43
Anyone have issues after the update with the sensor not blacking the screen out while on a call? I don't really want my face ending the call if its an important call. Using an iP5
Smarty2600
Apr 23, 2011
344
11
No it is not by design ever since iOS 3 or 4 and definitely with iOS 5 it did not do this. I have had iPod touches since the 2nd gen and I distinctly remember when having the wifi on in the background changed the way I used my iPod because I could rely on it for email notifications and news notifications and with iOS 5 iMessage and Facetime notifications. But now I can't rely it on it. So no it's not a battery saving feature, I have had the wifi stay on in the background when asleep for years and if you google it others are having the same the problem as myself.
Zanthe
#apple
Aug 9, 2007
2,638
323
When my phone goes to sleep it reverts to 3G/4G...always has. And that is why it may use small amounts of data when in sleep mode depending what apps are open.
Smarty2600
Apr 23, 2011
344
11
mrbunglez
Mar 20, 2008
439
100
43
So I've googled it and its not just me a lot of other people are having probs with the proximity sensor not working and having glitches after the update. Dammit!
