iOS 7 GM battery life :(
Feb 3, 2013
190
Hi everyone, Just wanted to ask if you're having the same problem? After I updated to iOS 7 GM yesterday my batt life was so awful. Drains soooooooooo fast. help pls :/
28,365
5,506
Let the phone drain down to 0% and power itself down. Then recharge it and post back if the battery life is still poor.
liberated
Jul 19, 2007
3,237
487
Did you restore from backup? Some of your apps may not be optimized for ios7 and that may have a negative impact on battery life.
spankbot
Sep 6, 2007
106
Completely draining your phone battery won't accomplish much as LiPo batteries don't suffer from the memory effect. Are you sure you aren't experiencing poor battery life because your just playing with it more? Which iPhone do you have?
28,365
5,506
It can reset/calibrate it so it reads more accurately. In these cases it's not that it's draining faster, it's just perceived that it is since the percentage is inaccurate. For example, I've seen people say theirs dropped rapidly after an update, but then it ran at 1% for an hour. Letting it power down isn't a guaranteed fix, but it's the first step in troubleshooting it. If it doesn't help, a restore might be in order.
spankbot
Sep 6, 2007
106
Draining the bettery to 0% doesn't reset the battery indicator, which I think is what you're refering to. To do that you just need to reboot (at least this was the case with iPhone 4).
28,365
5,506
Well, I've seen it help in some cases and it's a simple first step in troubleshooting. Letting it drain down to zero will show her if it's a consistent drop.
jalalawi
Apr 23, 2011
246
I think it is because our usage is very high considering we want to discover all the changes and the new features in the new software....
Sent using iCafe app
Feb 3, 2013
190
Yeeeeeeeeey! this totally worked. When my batt drained to 0% then charged it to full100% and did a hard reboot. Everything went okay then turned off theBackground App refresh and location
nealh
Apr 3, 2008
699
25
Apple actually recommends a full drain on the batteries as it does allow in some way more accurate battery % remaining. I have the FAQ on this
