iOS 8.4 Jailbreak Released
28,365
5,506
Just jailbroke my 5s on an old XP PC with an old version of iTunes. It worked the first time and only took about two minutes. I'm going to set that one up with all my tweaks and then restore/update and jailbreak my iPhone 6 later tonight.
Kadelic
Jan 4, 2010
4,935
1,645
Dallas, TX
Are you going to set up your 6 from scratch after the restore or apply your previous backup?
I just updated (no restore) from jailbroken 8.1 to stock 8.3 yesterday. I'm wondering If I'll be ok just updating to 8.4 and waiting for a Mac jailbreak tool, or if I should go ahead and do a factory restore. iCloud will recover my important data like Contacts, Calendars, Notes, etc, but I'll have to re-sync a lot of music which is time consuming. I think I ask this every time there's a new jailbreak because I am loathe to set up and re-sync everything, but still I ask, even though I know what you're probably going to say. :)
Napoleon PhoneApart
Jun 19, 2007
33,450
4,536
Upper Marlboro, MD
To give my two cents, I'm going to apply my previous backups on both my iPhones since the backups are so recent. And I'm a guy who loves to set up from scratch.
28,365
5,506
All of the jailbreak tweaks I had on 8.3 are working on 8.4 with the exception of f.lux and Activator. Installation of those two is disabled until they are updated for 8.4. Bytafont 2 is working and the San Francisco font does successfully apply.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Okay. It's supposed to fix the driver error. Let me know if it works.
Well I am at the point now, which is better than before, that says Taig can't find my device. When I open iTunes it states that "The file iTunes Library cannot be read because it was created by a newer version of iTunes." It could be due to me being on iTunes 12.2 on my Mac which I am using Parallels on. I am going to reinstall iTunes using the link you gave me, on Parallels.
Still same error when opening iTunes.
28,365
5,506
What I did a few days ago for 8.3 and then again today for 8.4 was uninstall all of my jailbreak tweaks, make a backup of the phone in iTunes, restore to factory settings, jailbreak and then apply my backup. This way my backup is as clean as it possibly can be while being made while currently jailbroken.
I've simply updated in the past (which removes the jailbreak) without restoring and then jailbroken the new firmware and had no problems, but it's not recommended. If it doesn't work, you can always restore at that point and then jailbreak and then apply your backup. The resync doesn't bother me much because I can do other things while it's doing its thing. It's setting up from scratch that I dislike.
Dec 15, 2008
5,386
340
27
Pensacola, FL
That is what I was instructing you to do. Maybe you misunderstood me. What's on the Mac side doesn't need to be touched - just the Windows side.
Yes. I didn't do anything on the Mac, but I installed iTunes on Windows using link you gave me. It gave me that error, then I reinstalled and now I am jailbroken. Odd. Thank you so much though!
