iOS 8 bugs
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
I had previously identified and posted about this bug which existed in iOS 8.3.
Today, I was able to test it on iOS 8.4.
It still exists. Apple has not fixed it yet.
As in my previous post, iOS warns me that it will not download an app update larger then 100MB via cellular, then proceeds to download it anyways.
The entire event takes places while I'm connected to a cellular network. I did not start out on Wi-Fi and then move out of range.
I would've recorded and shared a movie of the entire procedure, but doing so requires connecting the iPhone to one's computer via USB, at which point, the iPhone uses the computer's Wi-Fi connection even if Wi-Fi is turned off. Instead, I took several screenshots throughout the duration of the procedure, and I'm sharing them below:
An available update for the Numbers app is identified. The size of the update is 233 MB:
A pop-up indicates that the update will not be downloaded until the iPhone is connected to Wi-Fi:
The update begins downloading anyways:
The download of the update continues until completion and successful installation:
I will file a bug report on Apple's Bug Reporter.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
What kind of problem? Give as detailed an explanation of what is happening or not happening, as you can. What version of iOS you're using, what seems to cause the problem to come up, etc. The more detailed information you give the better the answer you will get back.
