iOS 8 compatibility ( & suitability )
dmoskaluk
Mar 22, 2013
306
45
65
Paynes Bay - Barbados
I realize that the iPhone 4 will not be updated to iOS 8, but that the 4s in theory will ..... I'd like some feedback from those who do the update on 4s, as I wonder if the phones operation might be compromised. I heard horror stories when iOS 7 came out, but other than the customary bug issues etc, all seems to have unfolded well. Does anyone have either positive or negative feedback after doing the update. Thanks kindly ......
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
I've heard the same about iOS 8 and the iPhone 4s. Arstechnica has a nice write up on iOS 8 on the iPhone 4s. There are assorted benchmarks, a list of things which won't work and their advice on whether to install iOS 8. Spoiler, they do suggest the upgrade.
dmoskaluk
Mar 22, 2013
306
45
65
Thanks Chris, and yes - I read Arstechnica's article, as well as a few others of a similar theme/genre. Since our 4S's are humming along smoothly on 7.1.1, I will, at least for now, leave well enough alone and stay status quo. I didn't do 7.1.2 because of documented issues by many users, and deep down believe 'if it ain't broke...................' particularly since many of the bells & whistles in iOS 8 either won't apply to iPhone 4s or aren't things I'd use a lot anyway. There 'may' be iPhone 6 in the future for us, but not likely this year. I remain interested in any comments from members re iOS 8 performance on any 'older' device, as I use an iPad mini ( non retina ) and my wife an iPad 2. All devices are doing well on 7.1.1, but seeing as the red 1 badge must remain on the settings icon, I simply moved the icon off the front screens. Too bad one can't inhibit this display - neat freaks feel 'sand in their shorts' seeing the prompt, but that's life :)
jc555
Oct 21, 2014
I made the mistake of updating to IOS 8 and it has destroyed my battery life. It is now sometimes as short as 5 hours and maybe as long as 12 (not often unless I don't use the phone at all). I am not a heavy app user or emailer or internet user so this has really pissed me off. It is not possible to uninstall 8 and go back. Next time I upgrade it may very well be to an Android phone. I'm tired of Apples' attempts to force you to upgrade their products.
28,429
5,552
If you are using an iPhone 5, check to see if your battery is eligible for free replacement: https://www.apple.com/support/iphone5-battery/
If it isn't, restoring or updating to iOS 8.1 will likely fix the problem.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
My iPhone 5 rarely reached 5 hours, and no it wasn't eligible for a free battery replacement. Settings and everything were checked to let minimum strain on the battery. I wouldn't worry.
And btw, it ran great on iOS 8
28,429
5,552
But jc555 said it drastically decreased on iOS 8. That's not normal. It helps to know the type of usage. Five hours of LTE Safari is normal, but two hours of facebook and texting with three hours of music isn't, for example.
jcg555
Oct 21, 2014
I have a 4S and when I said I wasn't a big user of email, internet or apps I meant I check email about 10 times a day, use Safari for no more than 30 minutes a day, check Facebook once or twice a day (spending maybe 10 minutes on it at one time) and I check Linkedin a couple times a WEEK. For example, so far today I have checked email 8-10 times, spent about 5 minutes on Facebook and checked 3 things on Safari. The real drop in battery life occurs when I use Facebook it seems. As soon as I do, battery life drops and continues to do so rapidly after I quit. Today, after turning my phone on at 6:30 am it was dead by 11:30 and it indicated 38% battery life left when it died.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
you said Iphone 5 and I thought that's what he/she had, my bad. I heard of people having bad experiences after updating to IOS8 on the 4S I actually texted everyone I know that had a 4S and told them to hold off.
28,429
5,552
Agreed. I would hold off, too. Running iOS 7 on a 4S would be frustrating enough.
jcg555
Oct 21, 2014
No problem. I just wish I'd gotten your text!
jcg555
Oct 21, 2014
Your right, it was. Funny thing is I'm not really a first adopter of tech items or software as I'm not that savvy. Guess I learned my lesson!
dmoskaluk
Mar 22, 2013
306
45
65
7.1.1 is fine on 4s .... Likely missing a few 'bells and whistles' only available on 5 and 5s but for normal everyday use ( email, iMessage, Web etc ) it is stable and (at least for me) decent on battery life and speed. But it sounds like doing iOS 8 would be like a non-swimmer going into the deep end and drowning ....
28,429
5,552
It's laggy. The old hardware can't run software that is several generations ahead of it without experiencing some lag. You'll notice the difference if you test a newer device on iOS 7 or 8.
iPutz
Nov 20, 2012
962
184
43
72
US Midwest
I updated my wife's 4S to 8.0 and two days ago to 8.1 and she's had no issues at all.
If it ain't broke, don't fix it!!
Sent from my iPhone 5
dmoskaluk
Mar 22, 2013
306
45
65
Out of the now in-vogue term "An Abundance of Caution" I will hold off, but can really say that I saw no degrade in performance on the 4S ( both my wife's and mine ) with update to iOS 6 ( it shipped with iOS 5, 2+years ago ) or iOS 7.....I did wait almost 2 months to do iOS 7 last year, ( iOS 7.0.4 ) was my first, but these comments cover the 2 phones, my iPad mini ( non retina ) and my wife's iPad 2 ... Probably not being big on a pile of apps and games ( except my wife's Candy Crush addiction ) has kept our needs relatively minimal, thus any performance issues ( lagging etc ) haven't been at an issue ( yet ) .... or maybe we're just 'old and slow' ourselves, as a reflection of age and tropical living, where not much happens fast anyway :)
