iOS7 question
Jun 29, 2013
So a friend of my taught he was doing me a favor by secretly installing iOS7 on my iPhone4. Once I figured out, I am NOT technologically savvy at all, I did a system factory restore. It did not help. When I connect with iTunes it says "Activation error. This Device is not registered as part of the iPhone Developer Program."
Another friend of mine suggested to put phone into DFU Mode, but my power button does NOT work. When the iPhone is on (plugged into outlet or computer) it is stuck in the "Select Your Country or Region" screen---sometimes it will show the Apple and connection cable as well.
Any thoughts or suggestions?
thanks
Scott
28,365
5,507
It sounds like it had beta 1 installed without getting your UDID registered with Apple through a developer's account. Is that correct? This is no longer allowed on beta 2 or any subsequent beta versions of iOS 7. A factory restore should put it back on 6.1.3. Do you have a valid SIM card in the phone? So just to clarify, you simply pressed the restore button in iTunes rather than hitting the shift key first and browsing for a firmware, right?
Jun 29, 2013
Yes, there is a SIM card is the phone. The factory restore or reset was actually done by going into settings and doing it there. Not in iTunes.
28,365
5,507
You need to restore in iTunes on your computer. It won't work from the Settings app since it needs to completely remove iOS 7 and install the full 6.1.3. The Settings app just lets you wipe data and install incremental updates.
Jun 29, 2013
I can not access my phone from iTunes. When I did the first reset it was from my phone in the settings. Now, whenever I connect my iPhone to the computer and iTunes comes up it says, "Activation error. This Device is not registered as part of the iPhone Developer Program." There are no options or anything inside iTunes.
Jun 29, 2013
The iOS7 worked fine. I just wanted it removed. So that's when I went into settings and did Erase All Content and Settings. Now when I connect it to iTunes, it has no options available and the screen in iTunes only says, ""Activation error. This Device is not registered as part of the iPhone Developer Program."
shutter13
Jan 8, 2009
2,201
144
You need to put your phone in DFU mode and when you connect the phone iTunes will prompt you to restore the phone.
You can find videos on YouTube with tutorials on putting your phone in DFU.
Jun 29, 2013
I can't figure out how to enter DFU mode with out a proper power button in the iPhone and without iTunes working--I have no options in iTunes.
28,365
5,507
Try doing a hard reset on the phone and rebooting the computer. Try a different computer if that doesn't work. Post back if that doesn't work.
The power button doesn't work on the phone.
Jun 29, 2013
Same thing on a different computer, but that was without a hard reset. My power button on the top of the iPhone doesn't work.
28,365
5,507
Can't do a hard reset without the power button either.
Buy a slot from a developer if iTunes will show you your udid.
Good idea. He might be able to do a legit install of iOS 7 after buying the slot and then downgrade properly through iTunes after that.
Jun 29, 2013
iTunes is not showing anything other than the screen that says, ""Activation error. This Device is not registered as part of the iPhone Developer Program."
28,365
5,507
I would do what Shutter13 just suggested and buy a slot so you can get iOS 7 legitimately installed. Then you can try downgrading in iTunes from there.
Jun 29, 2013
I can not access the "restore" or "check for update" options in iTunes. As soon as the iPhone is connected to iTunes, it immediately says, ""Activation error. This Device is not registered as part of the iPhone Developer Program" and has no other options.
28,365
5,507
Okay. First try using the directions Shutter posted for DFU mode without a power button. If that doesn't work, you'll need to try registering your UDID. If that doesn't work the only thing I can think of is taking it to the Genius Bar.
shutter13
Jan 8, 2009
2,201
144
If you buy a developer slot, your phone will be registered and that error should go away.
Jun 29, 2013
The option that shutter posted will not work b/c it requires iTunes to recognize the phone.
