Ip6 and iPad won't stream under same wifi
Jin
Oct 2, 2012
99
My iPhone 6 and iPad mini are streaming photo and media under same wifi in my house. All setting are turn on for stream. Only way to share is to turn on air drop for both device. Please any advice will help. Thanks
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
I'm not sure I understand the question?
B89rent89
Sep 19, 2012
170
17
You say "Won't stream" in the title and "are streaming" in the body of your postMUnich is it?
Jin
Oct 2, 2012
99
I'm sorry for typo, both device are using same wifi network. If I took a picture with one, should share to other device. Show up in the photo apps. But it doesn't. I have to turn on air drop to sent over instead. Hope this help.
5,578
There is a feature in iCloud that makes this automatic. After taking a photo on one device, it will show up in the Photos app on the other devices.
Settings > iCloud > Photos > iCloud Photo Library (beta) > On
Make sure you enable it on each device.
Jin
Oct 2, 2012
99
Ok I will try that. Thanks
