iPad 2 cam issues
AppleLady83
Sep 16, 2011
Just bought the 16gb iPad 2 and having problems with the camera, anyone have that same problem ? It works then the screen freezes and turns black, sometimes it won't even open
Try a hard reset. Press the home and power buttons at the same time. Ignore the slide to power off and let go when you see the Apple logo. No data will be lost. It's just a longer reboot. It frequently fixes problems like this.
