iPad 2 Safari crashing constantly!
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
Hey, I have an iPad 2 running 4.3.3. Safari crashes all the time! Does it happen to anyone else? Ive tried a hard reset, really don't want to restore because I'll lose my city story. Any ideas? It's stock, too. Thanks.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
why would you loose anything, all you got to do is backup your iPad.
RoofMonkey
Jun 21, 2010
8,924
1,983
I don't know, I got 77 apps running in the backround, it crashs on any site, here and other places.
Good lord... The memory on the thing isn't infinite! C'mon buddy, your smarter than this... Tsk tsk tsk
If it's jailbroken, get sbsettings and get the RemoveBG toggle. A swipe and 1 press: poof all background apps closed.
Sent from my iPhone
Try running just one or two Safari tabs at a time. I've had various Safari problems that resolved when I closed 6 or 7 of the open tabs.
Does it happen if you reboot daily and only run one or two Safari tabs at a time?
Settings > Safari > Clear Cookies/History/Cache.
If that doesn't help, try resetting all settings.
LrGolfer
Sep 19, 2011
In setting-safari
You can clear the history, cookies, and cache. Clearing the cache, in particular, can help solve issues, like constant crashing, that you may be having with Safari on the iPad. There is also a Developer tab you can tap that will enable you to turn on the Debug Console, which will automatically pop up to help with Web page errors.
