iPad 2 Zagg Screen Protector
Ut2729
Aug 17, 2011
14
Does anyone have experience using the Zagg screen protector for the iPad 2. Are they good or bad? Are there any better alternatives out there?
Ut2729
Aug 17, 2011
14
Would the bodyguardz screen protector? Would it work with the otter box?
joeg679
Jul 18, 2007
391
I've used the Zagg and didn't like it at all-very blurry. I got the SGP and wouldn't use anything else. Get the Ultra Crystal and you won't regret it.
Thiefxer
Jan 2, 2012
I just got one don't try to put it on yourself save urselft the trouble pay for a guy to do it at bestbuy or wherever you get it from its pretty nice fits perfectly and protects the screen
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
I have a cover case from Buy.com and ruined the screen protector because I wanted to get ALL the bubbles out.
I then immediately decided to go to Best Buy and of course the only case I saw and the guy sent me to was the ZAGG shield. I decided to let them put it on even though it costs $14 to do that. They did an amazing job except for a few micro bubbles which I was told go away after 24-48 hours. I like the shield. As long as it protects it and doesn't mess up, I'm happy.
