iPad 3 Jailbreak issues - Upgrading from 5.1.1 to 6.1.2
zandrik
Jul 27, 2007
175
I currently have a jailbroken iPad 3 wifi. I've done the following:
- Backed up to iTunes
- Pressed option+clicked update>choose ipsw(ios 6.1.2) file for my device (ipad 3 wifi)
- I get the error of ("your device is ineligible...")
- Search and find that my host file needs updated.
- I manually change it in terminal, still have issues, other erros, etc.
- I use TinyUmbrella and uncheck the, "Set host to cydia on exit..."
- Still won't work.
- I've tried putting it in DFU mode,.. still getting errors.
Am I missing something? Should "un-jailbreak" it to ios 5.1.1 (Current ios that the iPad is running) and then try to update?
Thank you in advance for your help!
28,365
5,506
You're just a couple days too late to do this. 6.1.3 came out on Tuesday and it's not jailbreakable. You can't update to 6.1.2 even if you have an SHSH for it. You'll need to stay on 5.1.1 if you want to remain jailbroken.
zandrik
Jul 27, 2007
175
I just tried restoring to 5.1.1 . Still getting ineligible device error. Not sure what to do. I've jailbroken several times. I've never had this much trouble.
zandrik
Jul 27, 2007
175
What about my iPhone 5? Can I update it? It's running 6.1
28,365
5,506
Only if you don't mind that it will become unjailbreakable. It can't be downgraded once you update. I'm staying on 6.1 and taking it easy with the new tweaks since a restore would force it 6.1.3 and stock.
28,365
5,506
Do you see the connect to iTunes logo on the iPad?
zandrik
Jul 27, 2007
175
I did, then it rebooted when iTunes gave me the error.
28,365
5,506
I'm not sure what you mean. Does the iPad need to be restored now or is it still working on 5.1.1?
zandrik
Jul 27, 2007
175
It shows the "connect to iTunes" screen, then reboots after the error. As if nothing has changed. It's still running 5.1.1 Jailbroken.
28,365
5,506
If it's still working on 5.1.1, stay there. You can't update.
If it needs to be restored, you can restore to 5.1.1 as long as you have a 5.1.1 SHSH and as long as you did a FULL update in iTunes to 5.1.1 when you initially installed it last year.
Directions:
http://www.ipadforums.net/jailbreak...5-x-ipad2-ipad3-using-redsn0w-shsh-blobs.html
If you did an OTA update to 5.1.1 last year or don't have an SHSH, you will have to restore to 6.1.3.
28,365
5,506
Okay, cool. Just stay on 5.1.1. You can't update it to 6.1.2.
zandrik
Jul 27, 2007
175
More than likely we won't see another jailbreak until ios 7. Don't you think?
zandrik
Jul 27, 2007
175
Could I restore my iPhone 5 (currently running 6.1 and jailbroken) to 6.1.2? Then jailbreak that?
iphonewarrior
13,847
701
Not possible unfortunately, the blobs thing doesn't work anymore :(
It's going to be the same for the iPad, if you update/restore it to iOS 6.1.2 it'll error as the firmware isn't being signed anymore by Apple. Only iOS 6.1.3 will work. Just stay where you are :p
28,365
5,506
No idea.
As stated above, no, that can't be done. But 6.1.2 is nothing more than a fix for an Exchange bug that may contribute to battery drain, so you aren't missing out on anything if you don't use Exchange.
zandrik
Jul 27, 2007
175
I am using exchange. That is the main reason I wanted to update. Oh well.
