iPad 4.3 GM Jailbreak
isal
Mar 22, 2009
136
Toronto
So i was able to successfuly jailbreak the 4.3 GM and got Cydia. Now Cydia does not open until one boots tethered. But I'm unable to boot tethered. I'm using Terminal and passing in the tetheredboot folder.
sudo -s
Users/name/Desktop/tetheredboot
./<the three files>
It passes the exploit properly but the iPad doesn't boot.
Any ideas?
TarekElsakka
Nov 14, 2008
6,844
415
Cairo, Egypt.
I did not use those when I used Terminal. In the tutorial video, the guy did not type those when he was using Terminal, but when he used Windows instead. Well, then, I guess that was the problem.
Hey, when I installed iOS 4.3, I couldn't see the icon organization in the Applications tab in iTunes. I also couldn't sync at all. Is that still the case?
iphonewarrior
13,847
699
That's because the iPad was already booted. The process will run, but it wont boot tethered at all. Terminal will just hang.
You need to type:
sudo -s
Enter Password
Drag TetheredBoot into Terminal
When you've dragged TB into Terminal, don't type space just drag in the file then type -i
Drag iBSS file into Terminal, again, don't press space, just write -k
Drag the kernel into Terminal, then tap enter.
You should see a White screen.
FYI - I've written this all here.
