iPad Air JB error 3014
jwolf
Jul 17, 2015
Hi, i've a iPad Air with 7.1 JB and when i tried to update to 8.4 the ipad stuck in the image of the cable and the iTunes. I've tried in two computers, without anti-virus and firewall, deleted the Apple register in hosts, and now tried in dfu mode and now i need some help to rescue the iPad. Thanks
5,578
Update iTunes to the latest version and make sure the firewall and anti-virus are still disabled.
jwolf
Jul 17, 2015
Hi, the iTunes is updated and all disable and still the error 3014
5,578
Can you post a screenshot of your hosts file?
5,578
The hosts file looks okay. Are both computers up to date? Do you have a third computer you could try? If not, I would consider using a VPN. You can disable it as soon as the restore completes.
jwolf
Jul 17, 2015
Yes the computers até both up to date, i don't haver a third pc. How can you want to use VPN? Thanks
jwolf
Jul 17, 2015
Yes the computers até both up to date, i don't haver a third pc. How do you want to use VPN? Thanks
5,578
The problem appears to be connecting with the Apple servers. Try this first:
1. Disconnect your home internet.
2. Toggle on Personal Hotspot on your iPhone. Settings > Personal Hotspot > On.
3. Go to the WiFi on the computer and connect to the phone's 4G/LTE.
4. Try to restore the iPad.
jwolf
Jul 17, 2015
Hi i've tried and don't solved, in other fórum a person said to install xp and resolved. What do you think? And in the iPad that you said to do i don't tried in dfu mode, is better trie this way?
5,578
1. It's drastic, but there is a good chance that would work.
2. Yes, try DFU mode.
jwolf
Jul 17, 2015
It's working, restored in another computer. Thanks
