iPad as a phone ?
bikerboy
Jun 20, 2009
263
Ohio, USA
Any idea if there is a way to use your Ipad 3 or Ipad mini as a Phone ?
not VOIP , regular phone to dial and text via GSM ?
I know there is an app for the ipad " 1 " but i am looking to use the 3 or the mini
Thanks in advanced sorry if repost.
raqball
Jan 30, 2011
1,079
198
So. California
What software are you talking about?
The iPad does not have the hardware built in for it to be used as a cell phone. VOIP apps / software is the only solution..
The only app I'm aware of that is non VOIP is for a jail broken iPad 1 that tweaks the 3G band or something like that. I think it's called Phoneit in Cydia but you will also need a phone SIM card in the iPad for it to work.
No clue if its available for anything other than the iPad 1 though.
Just use VOIP.. I do and it works great!
Edit to add:
Found this link for PhoneIt
http://www.iPhoneislam.com/phoneitipad/
iPad I only as you can read on the website
  • Like
Reactions: liberated
bikerboy
Jun 20, 2009
263
Ohio, USA
yep that is the one i meant, wish there were apps for more that just the ipad 1 , that would make a huge iPhone :p
bikerboy
Jun 20, 2009
263
Ohio, USA
That would work good with an American number but there is no way to pick an international number to receive call, lets say a middle eastern or east Europe number.
Sent using iCafe app
