iPad charging with iPhone charger.
Daniel_seward408
Jul 4, 2010
31
Just updated my new iPad (iPad 3) to iOS 6.0.1. Whilst updating I plugged it into the iPhone charger because in the past I've found that even though it says "not charging" it has always kept the charge. When the iPad restarted after the update it said it was charging. I thought it was a bug but the percentage is definitely going up.
Is my iPad tricking me or car I now charge my iPad from the iPhone charger?
Daniel_seward408
Jul 4, 2010
31
Yeah, but I'm charging the iPad off the iPhone charger. Thanks for your reply though.
aknightstale41
1,747
51
Long Island N.Y.
Ive read an article awhile back that said if you charge your iPhone with your ipad charger, you will have significantly reduced battery time due to the faster charge rate...i put it to the test and sure enough my iPhone drained much faster...in your case i would imagine you would have better ipad battery time...seems to be longer battery time with trickle charging.
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
The iPhone will only take what it needs to charge itself. Even though there are two amps available from an iPad charger the iPhone will only take the one amp it needs to charge. I have charged my iPhone 4, 4S and 5 a number of times with an iPad charger with no ill effects. Happy charging.
