iPad disabled
jafundy
Jul 5, 2007
216
11
Have a mini that won't charge and says iPad disabled. What can I do? Any way to do factory reset? Can't get off disabled screen.
Sent using iCafe app
Does the screen say try again in a certain amount of time? Is iTunes recognizing it? Is it your iPad and do you know the passcode and AppleID password?
jafundy
Jul 5, 2007
216
11
It is my husbands. Does not say try again. Will try to sync with iTunes.
