iPad freezes
tybirdtybird
May 6, 2010
435
42
Westfield, In
When I try and delete apps it locked up. The only way to get it back is hard reset. I sent feedback to Apple.
Hype-149
Oct 19, 2014
27
My iPad 3rd generation is pretty slow on iOS 9, slower then 8 was. Anyone have a 3rd gen iPad and notice this as well?
MikeSegal
Jul 10, 2015
It depends if you have back up of your device then you just used that back up and restore the setting you wanted but if you haven't back it up then reset to factory setting is the answer i guess.
