iPad mini theme help
ed2438
Apr 9, 2010
365
24
El Paso, TX
I am trying to theme my ipad mini and I have noticed that the mail app is one of the apps that does not change. I checked to see what folder it is that has the new icon and it is in the theme>Bundles>com.apple.mobilemail folder. Is this supposed to be different?
I haven't done any theming on iOS 6 yet, but I think the icon name for email is Icon@2x.png. Is yours named incorrectly?
ed2438
Apr 9, 2010
365
24
El Paso, TX
It's named correctly. I can change almost any other icon except the mail and safari one. To be safe and have the option to use it for all the other types of iOS devices, I have placed all the different files in there. Here is a screen shot of it.
Sent using iCafe app
Try fixing the I in Icon@2x.png. Yours is lowercase when it should be uppercase. It's case sensitive and won't apply if it should be capitalized and it's not.
ed2438
Apr 9, 2010
365
24
El Paso, TX
That worked. Thanks bro. It's weird because the icon for other apps work with a lowercase I. Nonetheless i will try both ways now. I am also stuck on safari. I tried both upper and lower case I.
Some of them need to be capitalized and some don't, but most are lowercase. The correct name for the Safari icon is icon@2x~iPhone.png.
ed2438
Apr 9, 2010
365
24
El Paso, TX
I went around putting the icons another way and it works better. What do you think so far?
