IPad Pro "rings" when Iphone rings?
B89rent89
Sep 19, 2012
170
17
When using my iPad Pro and my phone rings the iPad stops what it is doing and prompts me to answer. If I have no intention of taking the call on the phone then I'm not going to take it on the iPad either. Is this due to something in settings. Can it be turned off?
28,365
5,506
iPad > Settings > FaceTime > iPhone Cellular Calls > Off
iPhone > Settings > Phone > Calls on Other Devices > iPad > Off
B89rent89
Sep 19, 2012
170
17
Thank you Europa. Wouldn't have occurred to me to look under Face Time.
Mrallank59
Jan 8, 2013
247
31
Hey Europa, my iPad Pro has wifi as well as cellular. Does that mean I can place a call with my iPad ?
28,365
5,506
Yep. You can enable that feature here:
iPhone > Settings > Phone > Calls on Other Devices > iPad > On
Mrallank59
Jan 8, 2013
247
31
Thanks Europa. I've figured out that I can use Skype or any other number of apps but can my iPad Pro actually have a phone icon
Sent from my iPad using Tapatalk
Mrallank59
Jan 8, 2013
247
31
Also, with all the questions I ask you, I owe you a Starbucks cards or something similar
28,365
5,506
Thanks Europa. I've figured out that I can use Skype or any other number of apps but can my iPad Pro actually have a phone icon.
It can't have a phone icon. Basically, it's dependent on the iPhone and has to leech off of its number for cellular calls. It does this through WiFi just like Skype.
Haha! It's funny you mention that. I've been caffeine-free for over four years now, but I recently switched to early-morning shift and I'm starting to daydream about mochas now. I'm pretty sure I'm going to cave and go to Starbucks soon.
I'm happy to help and nothing like that is necessary. :)
