iPad Screen on PC
iNotes4You
Dec 8, 2012
59
GERMANY
iNotes4You.com
Good morning to the forum.
Is there any software available to display iPad's screen on a Win7 or Mac screen without installing any developer tools?
As I know AirDisplay from Avatron can show the computer's screen on iPad but not v.v.
Thanks a lot in advance and a streaming New Year to all of you.
Webster1999
Dec 29, 2012
It is possible to do it on a jailbroken iPad using Veency and then getting a VNC viewer like Tight VNC on your computer.
This way you can both mirror as well as control your iPad from your PC.
I don't think it is possible if you're not jailbroken though.
Sent using iCafe app from IPad 2 Wifi 32 Gb
applejosh
Oct 15, 2009
100
If you have the latest iOS and an iPad 3, AirServer (www.airserverapp.com) acts like an AirPlay receiver on your computer. Turn on AirPlay mirroring on your iPad, pick the computer as the target, and it displays your iPad screen on your PC. Handy if you do demos and such of iPad apps.
  • Like
Reactions: liberated
