iPad WiFi Issues
Discussion in 'iPad' started by chris, Apr 5, 2010.
  1. chris
    chris Administrator
    Anyone having WiFi issues with their iPad? I saw a few reports out this morning. Me personally, there were a few incidences where it took longer to connect upon powering up. Nothing that was really cause for concern.
    How about you? WiFi issues on your iPad?
  2. chris
    chris Administrator
    Powering up. That's so pre-iPad. It's more like turn on.:sneaky:
  3. Avatar
    Sponsored Advertisement
  4. up10ad
    up10ad Genius
    None here but I am headed to the You Tube thread.
  5. bostonkarl
    bostonkarl New Member
    Kinda Sorta
    My iPad wifi was being a bit cantakerous. Then I changed my router settings from mixed mode to G only. That cleared up all issues.
    Oh, and tethering using MyWi (jailbreak app) works very very well.
  6. BrownGem
    BrownGem Zealot
    No issues here. Instant connect at home and work.
  7. billnye97
    billnye97 Contributor
    I had a few instances of it not connecting. It was mostly turning it on and not giving it a chance to connect to the network.
  8. aggieman
    aggieman Zealot
    No issues at all here.
  9. Josh Yates
    Josh Yates Contributor
    No issues at home. Haven't gone out in the "wild" yet. We'll see how work and Starbucks does this week.
  10. iSoozin
    iSoozin Member
    No issues here either!!
  11. topspin
    topspin New Member
    mine is blazing, way faster than 3GS!!!
  12. leslivres
    leslivres Member
    yes, wifi issues. intermittent connections; doesn't hold for very long. just reading about the same problem with others. glad it was not "my fault." lol
  13. dcom
    dcom Zealot
    I'm having some WiFi problems. I connect to a Timecapsule using 802.11n and notice the signal fluctuates from full to 1 bar while sitting in the same place, holding the iPad the same way. It hasn't disconnected but the wavering signal is annoying. The speed doesn't appear to be a problem though, it's still fast.
    I have 2 networks at home, one is 'n' and one 'g'. I've connected to the 'g' net and I'm getting the same problem. There are no g devices connecting to the n net either so that's not the problem.
  14. up10ad
    up10ad Genius
    Same experience as dcom, Time Capsule has disconnected once while using LogMeIn to work from home.
  15. gulbane
    gulbane Member
    This is interesting because I was having wierd issues yesterday. Basically, I was getting intermittent wi-fi access. I would use the speedtest.com app which would show studdering and very slow download speeds. I used the same app on my iphone and it was perfectly fine at 22/4 after 5 tests in a row.
    I was wondering if I was having a problem with the ipad based on this. My router is a Wireless N. Any other thoughts on this?
    EDIT: Just saw the other posts that happened while I was typing. I wonder if wireless N is the issue?
    I swear it worked fine on Saturday and I had problems with it all day on Sunday.
  16. leslivres
    leslivres Member
    no issues with my iPhone. this was to be my "travel" laptop. wonder how this will all iron out?? Apple support document had a "Resolution" area but way over my head; all about appending one or more characters in the current network name.
  17. TechnologyCoach
    TechnologyCoach New Member
    I'm having connection issues - theres a certain amount of time of non-use when the wifi "turns off". If I open mail, or use certain internet dependent application, I get an error. If I open safari, a small window pops up and says "connecting" and I'm back in business. During the time when the wifi is off, if I try go to settings and try to connect to my network, it says unable to connect (even though I eventually connect).
  18. mori
    mori Member
    No issues here
  19. leslivres
    leslivres Member
    I find this tiring and more than a challenge!!! lol when opening Safari, I get the same connecting window. in between, I am having a nervous breakdown!! hoping this all evens out. running 5 miles a day helps, but might have to increase it to 10!!! hang in there.
  20. BrownGem
    BrownGem Zealot
    I'm wondering if this related to specific routers or MAC vs PC networks. I am running PC on a Linksys router. May be helpful if everyone posted that info. Might isolate a specific problem?
  21. leslivres
    leslivres Member
    am also running my PC on a Cisco Linksys router. still intermittent. just "live" for five minutes and then cancelled.
Share This Page
