iPad won't charge while attached to PC
James4455
Feb 20, 2009
West Texas
When the iPad is attached to the PC it syncs as advertised but the battery indicator states 'not charging'. The iPhone 4 charges while attached to the PC. What is the difference?
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
Hello! Your PC charges the iPhone 4 correctly because it uses a lower wattage then the iPad. The iPad uses 10W which your PC isn't designed to do, it charges. But it charges VERY slowly. But it shouldn't be displaying not charging. Try resetting it.
Chex
Dec 17, 2008
592
PA
If memory serves...It is charging even tho it says it isn't.
Try putting it in sleep mode, it should charge , even if its not a high powered usb2.0 port. What happens if you leave it overnight?
Sent by iPhone 5 using iCafe app...Voices of dissension are the root of change for unfair practices...
greasemuntney
Apr 4, 2010
103
Alabama
It will display not charging, this is normal like listed above it uses 10 watts were a iPhone uses 1.5-2 watt. The ipad will charge but do not use it during this time. Just put it to sleep and leave it connected. Do note if your computer goes to sleep it will kill the power to usb port and not charge. So computer has to stay awake. The new Macs has a higher wattage output just for these reasons.
15,385
1,023
all the info you need is here: http://support.apple.com/kb/HT4060
tl;dr: A lot of PC USB ports don't output enough power to charge the iPad. One thing you can do is try every port on your computer (especially ones on the back if you're using a desktop), because they're not all powered equally.
iphonewarrior
13,847
699
Just to clarify your computer will charge the iPad even when it says not charging. It will charge the iPad slowly as previously mentioned.
I had this problem with my 3 year old MacBook when the iPad 1 came out...
aihna
May 8, 2011
56
Just charge your iPad using its charger. It would be better and faster.
imutter
Apr 4, 2011
5,994
775
Somewhere between DC and Baltimore.
my iPhone charger and ipad charger look exactly alike so I had to mark the ipad one with a marker to not get them mixed up. It's best to charge from charger for the ipad and you should not hook the iPhone to the ipad charger either.
iNinja
Aug 8, 2008
3,985
20
UK
It makes literally no difference. They are just USB cables... the iPhone uses voltage control circuitry which means if you plug in an iPhone using an ipad charger it will limit the charge it receives / draw less.
If you plug your iPad into an iPhone charger then it will charge, but again, slower.
imutter
Apr 4, 2011
5,994
775
You changed your answer !
I never said it wouldn't charge either! I am kinda glad you went back after claiming they are the same
RoofMonkey
Jun 21, 2010
8,913
1,979
Your iPad charger isn't larger than your iPhone charger? phone charger on top - iPad charger on the bottom.
