iPad won't let me turn on Wifi
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
What happens when you toggle it on? Does it toggle itself off? Have you tried to "forget this network", then add it back?
Check to see if it works after each step:
1. Reboot.
2. Update the firmware.
3. Reset your network settings.
4. Reset all settings through the settings app.
5. Restore the iPad.
Jmt
Sep 11, 2011
29
Have tried everything digested here, nothing has worked, I guess a trip to Apple is next. Thanks everyone
So you restored it to factory settings? If that didn't work, take it to Apple. It could be a hardware problem.
Anthony Carver
Sep 15, 2015
40
You forgot Hard Reset is also an option, but it will wipe all the data. If you want you could do it by holding the home button and power button and following the instructions.
1. This is incorrect information. Please don't advise people if you aren't certain what will happen when you reboot an iPad.
2. I already told the OP to restore and he said he tried what I said and it still didn't work.
