iPhone 1.1.3 Installer
__DorkSterr
Jan 20, 2008
90
when ever I try to install anything it gives my a pop-up msg saying "Main script execution failed" whats wrong with it>?.
__DorkSterr
Jan 20, 2008
90
just these
BSD Subsystem
Installer
x999x
Aug 6, 2007
1,656
Yikes you're in the wrong forum with this post.
Head over to the Modifications or Third party forum, theres already threads covering this topic.
__DorkSterr
Jan 20, 2008
90
yes I do know how to add new sources.
i was reading other peoples post about similar problems and i bumped into this
"http://george.zjlotto.com/index.php/2008/02/02/fix-application-issues-in-113/"
its interesting because i did install an App called "installer space-limit fix" this is the description for it "fixes the problem of not being able to install more apps by lifting the space limitation for 3rd party" after successfuly installing this App it said that the program moved the directory of where the downloaded app are saved to the main partition?, could this be the problem? for "main script execution failed". P.S I did play around with iFuntastic and deleted some apps and not uninstall them properly.
