iPhone 1.1.4 restore file
PepeRB29
Mar 21, 2008
1,500
8 mile
i cannot for the life of me get an iPhone 1.1.4 restore .ipsw file to work to follow this guide
http://www.iclarified.com/entry/index.php?enid=1504
whenever i download it (i have multiple times) i get a folder with a couple different options that include
022-3894-4.dmg File
022-3896-4.dmg File
022-3900-4.dmg File
Firmware Folder
kernelcache.release.s518900xrb file
Restore.plist
and in the Firmware folder there is
all_flash Folder
dfu Folder
in the all_flash folder there is a
all_flash.m68ap.production Folder
in the all_flash.m68ap.production Folder there is
Applelogo.img2
battercharging.img2
batterlow0.img2
batterlow1.img2
DeviceTree.m68ap.img2
iBoot.m68ap.RELEASE.img2
LLB.m68ap.RELEASE.img2
manifest
needservice.img2
recoverymode.img2
and in the dfu folder there is
iBEC.m68ap.RELEASE.dfu
iBSS.m68ap.RELEASE.dfu
WTF.s5l8900xall.RELEASE.dfu
so i am just really confused as to what i am going to do, i downloaded the 1.1.4 firmware directly from the site and have downloaded from other sites as well and i get the same thing. if anyone can help i really appreciate it. thanks
PepeRB29
Mar 21, 2008
1,500
8 mile
well pending if this works or not, i just clicked on restore (using iTunes 7.5) and it is downloading 1.1.4 from iTunes. it was almost too simple to even think about so i will post up if it works. not sure what the files were i just posted, that crap was confusing as hell....
PepeRB29
Mar 21, 2008
1,500
8 mile
well it seemed to work, the only thing is i am stuck with my phone in restore mode and i was going to use ziPhone to kick it out and unlock it, but that doesn't seem to work, my question is if i use iliberty to do it, can i then restore and run ziPhone on it or what is the deal? damn this way more complicated than it needs to be, wtf?
PepeRB29
Mar 21, 2008
1,500
8 mile
so yah iliberty+ i can't do anything on because my computer doesn't recognize my iPhone now, and iTunes doesn't recognize it either, any help from someone smarter than me or who has done this before please!
PepeRB29
Mar 21, 2008
1,500
8 mile
can anyone help me? i have the 1015 error code which it says it is supposed to have, but i cannot activate it with anything (ziPhone, iliberty, pwnage 2.0.1) thanks
PepeRB29
Mar 21, 2008
1,500
8 mile
well i got it workin, did some more searching and found this tutorial over at hackthatiPhone.com. i'm kinda disappointed that nobody over here could help out, no hard feelings, but it is what it is. thanks for looking and hopefully this will save someone else from spending 5+ hours trying to do the same thing i did tonight.
http://www.hackthatphone.com/20/downgrading_2_0_firmware.html
adityaa19
Aug 10, 2008
its always showing me error 5 wat does it mean can u tell me
I'm not sure whether things worked out correctly or not, but in the original post, you simply had the unachieved version of the firmware. To get that folder to the IPSW (firmware) file, compress it, remove the .zip filename and add .ipsw.
