iPhone 2.1 software battery test
Sep 14, 2008
After experiencing crappy battery life with the iPhone 3g, I had high hopes when I heard about the features of 2.1, namely battery life. So after an entire day of heavy usage ( more than usual for the purpose of the test ), here are my results.
Settings
I started out with full battery, and reset statistics.
I had brightness at around medium
3G on the entire time
except while watching a 50 minute video, where it was off
Downloaded 11 or 12 apps from the store, tested them all. ( all dl'd over 3g.)
Used the maps for like 15 minutes
Listened to 10 minutes of tunes.
Browsed the web 1 hour.
****NOTE*****Plugged in for a quick sync, less that 5 minutes, did not significantly affect battery life
and after all that, i still had 20% left
hope that helps!
styfle
Mar 31, 2008
3,381
Everyone is going to call BS on you because the sync lol. Try not to sync next time so it doesn't show that it has been plugged in
Sep 14, 2008
wow,rightnow when I would have like 15 percent I have over 30. Great increase personally
