iPhone 2g Fw. 2.2 quickpwned but no cellular function.
gebrochen
Nov 23, 2008
Hi everyone, I was holding off on this because i really wasn't sure how it would go... Now I know why I waited.
I upgraded my iPhone 2G from 1.1.4 to 2.2 then ran quickpwn on my macbook successfuly but I have now lost the ability to make phone calls.
It recognizes my sim card with o2 Germany and allows me type the pin and unlocks but i have no coverage and no network. I basically now have ipod touch functionality with bluetooth...
I also tried PwnageTool but came to the same result.
Thank you for any help in advance.
Gebrochen (german for broken)
15,385
1,089
which .ipsw image did you use to create the custom one in pwnage tool?
15,385
1,089
ok, so it should be the .ipsw for the v1 iPhone... i would double-check just to make sure, though. The name of the file should be "iPhone1,1_2.2_5G77_Restore.ipsw". iPhone1,1 designates it is for iPhone v1, and not the 3G.
