iPhone 2g, phone part messed up?
davis5050
Aug 18, 2007
192
I have first gen iPhone and for some reason everything on it works fine but when i use the phone part or the visual voicemail function it blacks out to fast to hang up or listen to the vm. Did many restores and still not right. Any ideas?
bass_lover1
Aug 19, 2008
256
Sounds like the proximity sensor is going haywire. If the screen goes black when you're on a call but the phone is away from your face, it would lead me to believe this is your issue.
Unfortunately, I don't know how you can fix this issue because my guess would have been a restore which you've already done. Hopefully someone else can give you a hand.
