iPhone 2g SIM card in a 3G?
Hinezy
May 24, 2008
533
Mt.Carmel, PA
I was wondering what happens when you put an iPhone 2g sim in an iPhone 3g? The reason I ask is because I may be acquiring a 3g from craigs list and my wife currently has 2g. I'm hoping it would work fine and we wouldn't have to pay the $30 data plan since her account shows the plan for $20 on the 2g! Any help is appreciated.
ct2k7
Jul 7, 2009
145
The iPhone should work properly.
If you take the SIM out and locate a string on the SIM Card, somewhere you should find 3G. If not, it'll be a 2G sim and 3G won't work, so you'll need to contact your local psyphone provider.
iNinja
Aug 8, 2008
3,984
20
UK
I don't think it will work, im sure that in the US the original iPhone shipped with an Edge (non 3g) sim. Someone from the USA will confirm, but quite sure the original iPhones didn't ship with 3g sims
ct2k7
Jul 7, 2009
145
iNinja
Aug 8, 2008
3,984
20
UK
I couldn't find anything on the AT&T site, but might as well check with them to be sure.
Yes, definatly, the reason I think this is because the original iPhone was not 3g compatible and thereforee didn't need a 3g sim
ct2k7
Jul 7, 2009
145
That's what I thought, but apparently the SIM they provided is 3G compatible.
Hinezy
May 24, 2008
533
Mt.Carmel, PA
The only thing that has me skeptical is why wouldn't all 3g users call AT&T and claim that their 3g broke and they have since purchased a 2g so they would now like the data plan lowered from $30 to $20!?
ct2k7
Jul 7, 2009
145
Because I'd think that they have procedures before they issue a new device.
Spikey911
Oct 26, 2008
35
My 2g had a 3g Sim.... I am in USA
3g sim works just fine in the 2g.
I don't think the sim has anything to do with your data speed. I believe your plan dictates that, not the sim.
ct2k7
Jul 7, 2009
145
He sais 2G sim in iPhone 3G. Not just plan but other factors including signal strength affects data transfer rate.
Spikey911
Oct 26, 2008
35
I see, I misread what he typed, thanks for pointing that out :)
I think what he is looking for is if he will get 3g service but still pay the Edge price.... Don't know the answer to that..
ct2k7
Jul 7, 2009
145
there is nothing to distinuish between EDGE and 3G in terms of pricing.
