iPhone 3G electric help
iCafe
Dec 11, 2007
1,877
www.wwtdd.com
Any electritions out here know if it is possible to splice a home iPhone charger and connect it to a 12v wire and ground in a car ?
psylichon
Oct 31, 2007
16,591
751
41
Philly
It will require all different electronics for that power conversion. Can I ask why?
talon90
Jan 17, 2009
290
29
I agree with psylichon. As I recall the USB 2.0 voltage spec is 4.75 to 5.25 VDC. You would need to transform the 12.0 VDC output from the car down to 5 VDC to avoid frying your iPhone.
The Apple
3,105
Indiana
Electrition is a misspelled version of electrician. An electrician is one whose occupation is the installation, maintenance, repair, or operation of electric equipment and circuitry.
iCafe
Dec 11, 2007
1,877
www.wwtdd.com
LOL
titty dave are you serious with that car charger LOL
What I want to do is hide my wires behind the dash , and charge my iPhone 3g while getting video and audio to my indash
Now I am thinking of connecting a ciggarete lighter adapter to a 12v wire and grounding it behind the dash while using it for power with a powerjolt griffin and the USB from the Apple composite cable
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
Oh.
I thought it was some newly-discovered subatomic particle I wasn't aware of.
psylichon
Oct 31, 2007
16,591
751
41
Philly
LOL
Just trying to save you from yourself. Folks who can't spell electrician probably shouldn't be playing with electricity. But by all means, knock yourself out with that gameplan there.
iCafe
Dec 11, 2007
1,877
www.wwtdd.com
I don't think my electrician can spell his name but he is a beast with wires
does no one know how to wire a iPhone usb cord to the car directly
6,682
49
before going all out and tearing up a cord, take a look at this:
http://cablejive.com/chargeconverter.html
This is made to correct the problems with going from the firewire charging method to the USB2.0 that the 3G uses.
The Apple
3,105
Indiana
You would not wire a usb cord direct to a cars voltage system. You have to regulate the dc from 12v to whatever voltage the iPhone charges at which is......5v 1 amp it looks like. If they don't market a direct wire in you would be best to "hack" a cigarette lighter plug in charger. I will see if I can find a good option for you and return, hopefully with some good news.
psylichon
Oct 31, 2007
16,591
751
41
Philly
Dude, seriously, take it in to someone who knows what the heck they're doing. Your dash and your iPhone will thank you for it.
The Apple
3,105
Indiana
Don't let Dave make you scared. You can always install an accessory cigarette lighter socket behind the dash and plug in the regulator to that. Simple but not the cleanest setup.
psylichon
Oct 31, 2007
16,591
751
41
Philly
You're right. iCafe, you should definitely try this. And please, post pics of the process!
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Like everyone says, you cannot charge/power an iPhone off of a direct 12v source (bad things will happen). What exactly are you trying to achieve? Just want to be able to charge and have audio by just using the dock connector? What kind of aux input do you have on you head unit?
