iPhone 3G No Signal, No Service
jhimhope
Jun 24, 2009
:oops: :oops: :oops: Hi everybody good day! I'm newbie here and new using iPhone, i had an iPhone brought 3 weeks ago, since it was new there is nothing problem. But since i updated in 3.0 using iTunes my simcard doesn't recognize anymore and i was stock on emergency call. I restore to 3.0 ipsw beta using iTunes 8.2 luckily it was successful but i don't get any signal and sometimes it says no service. :oops: :oops: :oops:
Attempt solution:
1. Reset Network
2. Hard Reset
3. Take out SIM and reset Network, Nothing happens
iPhone 16Gb, Model: A1241, Sim: Etisalat UAE...
What do you think guys happening to my phone. Help is highly appreciated.
Thank You.
jhimhope
Jun 24, 2009
@sampalmlove007, thanks for the reply but i can't get back in to the 2.2, it's getting an error 1600, 1601 or 1602. I am using iTunes 8.2. need help huhuhu
cevtv
Nov 23, 2008
51
sampalmlove007 said:
poor guy,firmware 3.0 is not steady now,my advise is going back firmware 2.2,and waiting Apple solve all the problems.
What the hell are you talking about? :rolleyes:
Neo-Tech
Oct 24, 2008
254
Restore to 3.0 final, it that doesn't work, do a DFU restore. Then JB and use ultrasn0w, unless if Etisalat works.
iphonewarrior
13,847
701
What what what?
I suggest performing a restore. If your current carrier is 'legit' to run on the iPhone without any unlocking method involved then you should be fine. Restores usually get rid of most of the problems. You may even have an actual problem with the phone itself or perhaps the sim card. You have to think about these factors when trying to de-conflict your iPhone associated problems :laugh2:
jhimhope
Jun 24, 2009
Hey guys thanks to your help, I've got some idea to all of your suggestions now my iPhone is working fine and i can used any SIM.
Solution I made:
1. Restore iPhone using the 3.0 ipsw with iTunes 8.2 (latest one)
2. Install Cydia and Icy
3. Add repo (repo666.ultrasn0w.com) to Cydia
4. Search repo to cydia and run. wait phone it will restart
5. Done!
Thanks to dev team and all of you guys... a million thanks
5.
nuwan85
Jul 11, 2009
please help meee
i am also faceing same problem.. i did same all things but still my phone no service. please help me guys.. :(:(:(:(:(
Neo-Tech
Oct 24, 2008
254
Restore your iPhone to 3.0. Download redsn0w and jailbreak your iPhone (Install Cydia). Then add the repo in Cydia and install ultrasn0w. Then go in to Settings > General > Reset > Reset Network Settings. If no signal then it could be your SIM Card.
nuwan85
Jul 11, 2009
Thanks for quick reply
Thanks for quick reply.. today i will try.. could u please tell me proper iPhone 3.0 (3G) firmware link...
and my sim is ethisalat u.a.e
Jun 30, 2009
231
You already have applied all possible solutions. I don't think there is any other way out. Please do check one more time.
buboy1023
Sep 4, 2009
Solution I made:
5. Done!
5.
Thanks to you bro jhimhope, this is the best solution i got.
guys this is highly recommended. God bless
