iPhone 3G won't turn on
cesarxp2
Apr 14, 2009
so i don't know what happened, but i have a jailbroken iPhone 3g, and it worked fine until i restarted it and now it doesn't turn on past the startup logo! when i connect it to my computer, iTunes recognizes it and it shows all my songs and photos, but my ihpone is still in the startup screen...is there any way to get it back on WITHOUT restoring it?! please help!
or if i have to restore it, then how can i save my music inside the iPhone because my iTunes music is really unorganized and it has music from my friends which i dnt want and im too lazy to put every single artist again and album art, etc..
iNinja
Aug 8, 2008
3,984
20
UK
download ifunbox or similar and plug in your iPhone. If that recognizes your phone then download all your music into a folder.
Then, after restore, sync that music?
If its not booting up and its under warrantee then get it swapped. They cant tell its jailbroken if it doesn't switch on ;)
Jun 4, 2010
hi all
my iPhone 3g suddenly stopped working. I was charging it via my laptop. Lights went off and now it is dead . please help!
Preme
May 30, 2010
22
Try holding home button and power button at the same time for 15 seconds.
If that doesn't work, try dfu mode restore.
If THAT doesn't work get a new phone :) ( if it's not covered under warranty)
Jun 4, 2010
yes holding home button and power button worked!
thanks a lot mate!
A&A
Preme
May 30, 2010
22
No problem dude, press my Thanks button please :)
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
My friends 3G iPhone won't turn. She bought it off eBay Monday. From My understanding, it would not do anything. She tried a hard reset. It then would not power on. She took it to the AT&T store and they just popped the SIM back in her old phone. Apple won't do anything, I already told her that. She's shipping it back, unless I fix it. It sounds like a rotten battery. The biggest problem is I cannot hook it up to my computer, as that would be the first computer to be plugged into. Any help? Would plugging it in to the wall, and holding sleep+home for a long time. I might plug it in to see If iTunes can recognize it. any help on what I can do? Thanks.
I'm kinda hoping she can't send it back. I'd really like to take it apart and put in a new battery. :)
Oct 5, 2010
1,155
20
25
Ireland,UK
if its on eBay get her to open a resolution case and get her money back , no point paying to fix a broken item when good money was paid .
28,365
5,506
You can hook it up to your computer. It doesn't matter that it would be the first computer it was connected to after purchase. Try DFU mode.
