iPhone 3GS 3.0.1 here with jailbreak/unlock, VVM not working!
ckpatel
Aug 22, 2009
ok so i have an iPhone 3GS. It is running 3.0.1 firmware. I have the MMS working and tethering...It is jailbroken, and I am using AT&T. I also am using the 5.0 carrier file. so all is working perfectly except when I try to use my visual voicemail it calls my voicemail like a regular non-iphone, and doesn't use the actual visual voicemail. Now I have tried resetting my network settings because apparently several people say that is the "fix" to this problem, but it has not worked for me!:( does anyone know of any other fix for this problem to get my VVM working?! thank you!
billinaz
Jan 27, 2008
164
I had this problem, and there is a thread I started for it.
You just need to install supreme preferences 3.0 and change your voicemail address in the cellular network settings tab.
Works again after that.
