iPhone 3GS 4.3.3 problems.
Thomas Connor
Jul 23, 2011
Dublin, Ireland
I have updated two iPhone 3gs to 4.3.3 and both not working now. First the signal went now battery won't take a charge. Can't power up enough .Can somebody tell me how I can erase iPhone 3GS without iTunes or access to phone has to be done from laptop.
moonfish
Feb 17, 2011
68
Really? Both wont charge?
Silly question, have you turned the off then back on? Or won't come back on at all? :eek:
Tommy Connor
Jul 23, 2011
Santry
Yes have done everything. When plugged into laptop will only give Apple on black screen then when plug into mains power it will give up Apple and white cable with slider but as soon as I unplug it switches off no power at all. Have giving everything a try am bring them into a shop who can completely wipe an iPhone. Have had the batteries looked at and one is new.
moonfish
Feb 17, 2011
68
What happens when you hold the power and home buttons down together for 5 - 10 seconds?
MrMike6by9
Nov 16, 2008
1,482
119
72
Maryland, USA
I let my Gs run down to "0" the other day. It had to be plugged into the AC adapter for about 20+ minutes before the screen would show anything other than the empty battery icon. Make certain you're using a USB port that is "full" power. Often, some ports don't provide as much juice as some others.
YMMV
Sent from my iPhone using iCafe app.
krishnamraju
Sep 28, 2011
press home and power key for ten seconds and screen go black and now relese power button while holding home button for 10 or 15 seconds u will be in dfu mode
