iPhone 3GS is not charging!
Oct 22, 2009
my iPhone 3gs show the "charging" icon in the battery indicator but the battery is actually not charging. tried all sorts of charging through pc/wall socket. just not working.
I was using a car charger, belkin fm transmitter suddenly it restarted itself after an hour in belkin. Now its dead cant charge or open.
my question is! could it be short circuit? if short circuit would the phone still operate on the battery until it drains out?
Co-Mau
Oct 25, 2009
Chicago
Sounds like the phone itself. You should still have Apple support on the phone. All you have to do is take it into your local Apple store and then talk to a Genius and the Genius Bar. They will help you with everything. Most likely you will be walking out with a brand new battery in your phone. Or a new iPhone if your lucky enough..
iNinja
Aug 8, 2008
3,984
20
UK
Car charging with the 3GS is also a little misleading. Unless your charging via a cigarette lighter, you may not be getting the correct power to the phone.
I know personally that in my car, although the charging symbol shows the iPhone doesn't charge unless i plug it into a cig lighter and USB.
Tug
Aug 4, 2008
528
If it's not charging I don't think I'd give it to much concern, contact AT&T tell them about the problem and get a new phone.
Murdomac
Jul 3, 2009
I would be interested in what model iPhone you have, I'm now on my third new handset in as many months, both the privious ones (32mb 3gs) died whille tring to charge them.
The 1st handset I had got really, really hot before it died.
I think there was a bad batch of phones or batteries, but had no trouble exchanging them.
PinkBanana
Feb 16, 2010
1,472
92
Burnley, UK
My 3GS will not charge. The home button doesn't work, when someone calls me, I can hear them but they can't hear me. It's jb on 4.1 with limerain. Should I take it to Apple?
PinkBanana
Feb 16, 2010
1,472
92
Burnley, UK
Its not toasted because it still allows me to use it and send messages etc, I just can't use my home button, it wont charge and if im on a call the person on the other end can't hear me. But |I can still hear them.
As far as restoring it goes, how am i supposed to do that when it won't allow me to connect my phone to its charger or the pc using usb. It was perfectly ok when i left my boyfriends brothers on new years eve.
FlwrPwer
Aug 7, 2008
1,855
77
39
Montgomery, NY
If you take it to Apple you have to do a restore. They won't touch a jailbroken phone and if they do, they're going to charge you for it because the warranty was voided when you jailbroke it.
FlwrPwer
Aug 7, 2008
1,855
77
39
Montgomery, NY
Honestly, I'm not well-versed enough in "troubleshooting" jailbroken phones. This is why I don't jailbreak. With my luck, something like this would happen and I wouldn't know what to do. Right now, I think your best bet is to wait until someone with more knowledge signs on and answers your plea. I'm sure there are multiple people on this forum that will have better ideas.
FlwrPwer
Aug 7, 2008
1,855
77
39
Montgomery, NY
How long is the warranty valid for though? It might be out of warranty.
I *think* it's a year....and then Apple Care will add another year if you bought that. I'm not really sure what happens when you bring a jailbroken phone into the Apple Store. I know that when I had issues with my jailbroken phone, I restored it first. Again, maybe someone else here has more knowledge of this.
FlwrPwer
Aug 7, 2008
1,855
77
39
Montgomery, NY
It's out of warranty then, I have had it 14months. Didn't buy it from Apple, got from an orange shop in the uk.
Well then, do what you feel is the right thing to do. I have given my advice which is to wait a bit until someone with more knowledge answers your question with maybe a fix. But you seem to be ready to head to the Apple Store, so it's your phone, do what you will with it.
PinkBanana
Feb 16, 2010
1,472
92
Burnley, UK
I just wish it hadn't picked now to decide to **** up...
