iPhone 3GS keyboard problem
daslicer
Nov 20, 2011
hello,
the lower-part of my iPhone 3gs keyboard seems not to work anymore, while not using the keyboard the lower-part of the screen does work. is there anything i can do to fix this? because i can't text anyone and i can't even search on internet!
please help me.
iBoss
Oct 15, 2011
250
53
Sounds to me like you need a new digitizer! Did you drop your phone? Did it get wet?
daslicer
Nov 20, 2011
no i didn't drop him and it didn't get wet... only the lower-part of the keyboard doesn't work, the upper part still works.
Docd
Oct 16, 2011
651
62
Happened to my wife's 3G. The wiring came loose to the bottom part of digitizer (I guess it attached in sections). Apple tech opened it up and pushed it back and worked fine for awhile but ended up replacing the phone.
