iPhone 3GS loses signal when connected to USB
JoshDave
Dec 19, 2011
Hi my iPhone 3gs 16GB loses it's signal when I connect it to USB>computer/charger
I have 4.3.3 FW.
It seems like the usb acts as antenna when I connect it. because the signal goes up when I put the USB's other end to a higher place.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I have 4.3.3 FW.
I am confused. Your reception gets better or worse when plugged in. Your post said both.
JoshDave
Dec 19, 2011
ok sorry for confusing you. what happens is when I connect it to my computer I lose the signal. probably because the other usb end is in the computer. but when I remove it from the computer's port and put the other end in a higher place I get some bars
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Set the phone down on the desk. How many bars do you have? And in the same position when you plug the cable into the phone them computer?
JoshDave
Dec 19, 2011
same position 2-3bars when unplugged. but when plugged same position I get "No service"
JoshDave
Dec 19, 2011
I've been having signal issues since I got this fone, it's 2nd hand. but its about 2 days since I noticed that it's because of the USB
JoshDave
Dec 19, 2011
I tried 3 different cables from my brothers iPhone 3gs and ipod touch 4g too same problem. yes it does happen even through a wall outlet
