iPhone 3GS stuck at Apple Logo becasue System Memory is Full
jsg1163
Feb 27, 2012
Birmingham, United Kingdom
Hello,
I have iPhone 3GS and its been Jailbroken for over 2.5 yrs. I've never ever-ever had any problem in the past.
Yesterday I checked that Cydia showed that my System Memory is 88.6% full and there were couple of updates in Cydia. I updated all Cydia apps and it asked me to "Reboot Device". (see image below)
Ever since, my iPhone has not started.
I have tried almost every single method by like holding he Power and Sleep button for 10 secs, putting it in DFU mode, change computer, change iTunes etc.
My iPhone still stucks at Apple logo and does not start.
When I try to put it in DFU mode, it comes up with USB logo connect to iTunes, but iTunes doesn't detect the iPhone. (Please see image below)
I have tried various methods 20 or more times but no use. Now, the battery had completely run out and I have even left my phone on for 5-6 hours on charge but still no use. (see image below)
Every time I put it on charge, it comes up with Apple logo and stuck, it restarts after sometimes and this keeps going on in loop. (See image below)
Can anyone please help me on this issue.
My device details are:
iPhone 3GS
16GB
iOS 4.3.3
Jailbroken using www.jailbreakme.com
Moved to iPhone Jailbreak.
Restoring it is the only option. Keep trying to get it in DFU mode - it can be difficult. Try using another computer if you have access to one.
jsg1163
Feb 27, 2012
I have tried using a brand new computer with newly installed iTunes, but same problem. Tried this over 10-15 times but no results... :(
iTunes doesn't even detect my device when it says on the screen that connect USB to iTunes.
It's not in DFU mode if you can see that screen. Keep trying to get it into DFU mode. The screen we be black and it will look like it's turned off.
jsg1163
Feb 27, 2012
And, adding more to this, the battery was fine till morning, but now its been over 6-8 hours that my iPhone is on charging, but the battery is still empty and phone shuts down after 2-5 mins when I disconnect the USB/ Main A/C power cable.
I know. iTunes won't detect it until it has successfuly been put in DFU mode. If you can't get it in DFU mode, it's a brick, unfortunately.
badrys
Jun 11, 2012
Hi jsg1163,
I just had exactly the same issue with similar circumstances (iPhone 3GS, Apple logo loop).
Could you please tell me if you managed to solve your problem ?
Thanks in advance
PinkBanana
Feb 16, 2010
1,476
94
Burnley, UK
The only way to fix it is to restore it after getting it in DFU mode.
http://www.iclarified.com/entry/index.php?enid=1034
Europa knows her stuff matey. Try following the instructions she's supplied for you.
...and I guess it won't go to DFU mode because it is bricked....hahaha, so we are in a loop now.
Any one else please...!
You must not be getting it into DFU. Make sure you are definitely following the instructions. It takes a few tries if you're not used to doing it.
badrys
Jun 11, 2012
Unfortunately I've already tried that many many times !
no matter for how long I keep pushing the Home+Power buttons, it just never turn the phone off :(
It is only turned off when the battery is empty, then when I plug it into USB port, the Apple logo appears again automatically as soon as the battery containes enough energy.
... and there is the loop :( I am really desperate now (n)
