iPhone 3GS Update/Unlock Problem
kirsty21
Mar 8, 2012
my daughter purchased a second hand iPhone 3gs which had a new payg orange sim registered to it.she got it unlocked for £25. when turning phone on it got stuck on the Apple logo and wouldn't do anything else. she then had to do a reboot to the phone which she then had to connect the iPhone to iTunes to restore it. it was then back to its factory settings and had to reactivate the phone. asked for country and wi-fi set up to activate the sim card. then clicked the correct wi-fi network, then clicking next to activate. was told it would take 3 minutes to activate, then come up with a message on the iPhone & in iTunes that there was no sim card in the phone. please help !
iphonewarrior
13,847
699
Thread moved to the iPhone Unlock section. Thread title modified and prefix added.
I would attempt to clear any possible debris from the SIM tray. But. You've paid £25 for an unlock (which is free by the way...), which is now redundant because you've locked the phone again by restoring it. When you restore the phone, think of it like reformatting your computer. You will have updated the phone's baseband which, at present isn't unlockable, unfortunately.
There are methods to unlock the phone; install the iPad's baseband - there are complications when/if you do this.
tomm1
Sep 10, 2012
In second hand iPhones there is always problem exists. You can try resetting the phone using
the master reset codes from the online site.Anyway if you want to unlock Onlinegsmunlock.com
your iPhone3gs with orange network using the remote unlock method.You can get the remote
unlock services from the site Onlinegsmunlock.com and unlock it easily.
